Hybrid General Electric Radios Anyone?
I've tried the 50C5 sub on two radios, supposedly just a plug and play sub. Neither case worked and I had to go right back to to 35C5. I'll try and get a picture of the T1243B soon. Also, I'm going to see about getting that one worked on soon as well. Want to see how bad one of these might be to work on as they are usually dead on the FM side. The T1240A is the first one I've ever had that works fully on both AM and FM. I had one years ago that needed work, but turned my nose up at it and sold it with a batch of table radios I decided I wasn't interested in dealing with.
Hybrid General Electric Radios Anyone? - by Jayce - 12-15-2018, 06:35 PM
RE: Hybrid General Electric Radios Anyone? - by Jayce - 12-18-2018, 11:30 AM
There are currently 8545 online users. [Complete List]
» 3 Member(s) | 8542 Guest(s)
