Packard Bell 48D re-cap
The schematic for this has a lot of symbol for the band switch that makes things a bit obscure for me but I've looked at some others that show an antenna clearly going to ground. So I guess that's fine. Other radios that I have seems to have a cap keeping the antenna wire from being grounded, none of the other radios show continuity between the antenna wire and chassis.
So back to staring at this thing. I've checked the coils but I guess I'll give them another look. When I send an RF signal into the antenna wire it comes out the speaker but really low, it's not getting amplified?
Alan
Packard Bell 48D re-cap - by lasurveyor - 12-08-2018, 02:42 PM
RE: Packard Bell 48D re-cap - by jcassity - 12-09-2018, 01:55 PM
RE: Packard Bell 48D re-cap - by David - 12-09-2018, 02:20 PM
RE: Packard Bell 48D re-cap - by morzh - 12-09-2018, 02:24 PM
RE: Packard Bell 48D re-cap - by lasurveyor - 12-10-2018, 05:16 PM
RE: Packard Bell 48D re-cap - by morzh - 12-10-2018, 05:40 PM
RE: Packard Bell 48D re-cap - by jcassity - 12-10-2018, 05:48 PM
RE: Packard Bell 48D re-cap - by lasurveyor - 12-10-2018, 06:40 PM
RE: Packard Bell 48D re-cap - by lasurveyor - 12-10-2018, 06:45 PM
RE: Packard Bell 48D re-cap - by David - 12-10-2018, 07:21 PM
RE: Packard Bell 48D re-cap - by lasurveyor - 12-20-2018, 01:04 PM
RE: Packard Bell 48D re-cap - by Phlogiston - 12-20-2018, 01:33 PM
RE: Packard Bell 48D re-cap - by lasurveyor - 12-20-2018, 06:15 PM
RE: Packard Bell 48D re-cap - by jcassity - 12-21-2018, 12:15 PM
RE: Packard Bell 48D re-cap - by lasurveyor - 12-21-2018, 12:30 PM
RE: Packard Bell 48D re-cap - by jcassity - 12-21-2018, 12:38 PM
RE: Packard Bell 48D re-cap - by jcassity - 12-21-2018, 12:41 PM
RE: Packard Bell 48D re-cap - by lasurveyor - 12-24-2018, 04:23 PM
RE: Packard Bell 48D re-cap - by David - 12-24-2018, 10:09 PM
RE: Packard Bell 48D re-cap - by lasurveyor - 12-25-2018, 10:45 AM
RE: Packard Bell 48D re-cap - by OldRestorer - 12-27-2018, 08:13 AM
RE: Packard Bell 48D re-cap - by jcassity - 12-27-2018, 12:09 PM
