model 41-280 noisy static
> Should I hear no static that would be the stage in trouble? Yes but check the stage before and after to be sure. If you have a tracer sometimes you can find the faulty stage but if the noise is coming from the hv (like arcing)sometimes it will show up everywhere w/the tracer. In that case you can disconnect the hv feed stage by stage to find the fault.
Have a look at 26,28, and 30 these could cause low voltage on the XXL's. Here's a better diagram: http://www.audiophool.com/Philco.html
model 41-280 noisy static - by madsowry - 12-25-2018, 06:47 PM
RE: model 41-280 noisy static - by Radioroslyn - 12-25-2018, 08:34 PM
RE: model 41-280 noisy static - by madsowry - 12-25-2018, 11:15 PM
RE: model 41-280 noisy static - by radiodale - 12-25-2018, 11:48 PM
RE: model 41-280 noisy static - by Radioroslyn - 12-26-2018, 12:10 AM
RE: model 41-280 noisy static - by madsowry - 12-26-2018, 04:29 PM
RE: model 41-280 noisy static - by Radioroslyn - 12-26-2018, 04:32 PM
RE: model 41-280 noisy static - by madsowry - 12-26-2018, 06:06 PM
RE: model 41-280 noisy static - by Radioroslyn - 12-26-2018, 06:21 PM
RE: model 41-280 noisy static - by madsowry - 12-26-2018, 06:32 PM
RE: model 41-280 noisy static - by madsowry - 12-26-2018, 06:39 PM
RE: model 41-280 noisy static - by Radioroslyn - 12-26-2018, 08:23 PM
RE: model 41-280 noisy static - by madsowry - 12-26-2018, 10:15 PM
RE: model 41-280 noisy static - by Radioroslyn - 12-26-2018, 10:22 PM
RE: model 41-280 noisy static - by madsowry - 12-26-2018, 11:58 PM
RE: model 41-280 noisy static - by Radioroslyn - 12-27-2018, 12:11 AM
RE: model 41-280 noisy static - by Radioroslyn - 12-27-2018, 12:16 AM
RE: model 41-280 noisy static - by madsowry - 12-27-2018, 12:40 AM
RE: model 41-280 noisy static - by Radioroslyn - 12-27-2018, 12:58 AM
RE: model 41-280 noisy static - by madsowry - 12-27-2018, 01:35 AM
RE: model 41-280 noisy static - by madsowry - 01-08-2019, 08:22 PM
RE: model 41-280 noisy static - by KCMike - 01-08-2019, 11:01 PM
RE: model 41-280 noisy static - by Radioroslyn - 01-08-2019, 11:03 PM
RE: model 41-280 noisy static - by madsowry - 01-09-2019, 12:39 AM
RE: model 41-280 noisy static - by madsowry - 01-12-2019, 04:48 PM
RE: model 41-280 noisy static - by KCMike - 01-12-2019, 06:36 PM
RE: model 41-280 noisy static - by madsowry - 01-13-2019, 09:13 PM
91H Code 126 Restore
There are currently 4814 online users. [Complete List]
» 2 Member(s) | 4812 Guest(s)
