Zenith 10-s-464
I tried wiggling the tubes and then tapping on them but nothing changed. I poked around underneath with a platic chop stick and everything seems fine.
I forgot to mention that the tuning eye tube is no longer lighting up.
I’m thinking I may have take the volages from the tubes to see if something stands out.
Zenith 10-s-464 - by Tucker - 12-26-2018, 08:13 AM
RE: Zenith 10-s-464 - by morzh - 12-26-2018, 09:49 AM
RE: Zenith 10-s-464 - by Tucker - 12-26-2018, 10:05 PM
RE: Zenith 10-s-464 - by sdradioman - 12-27-2018, 08:42 AM
RE: Zenith 10-s-464 - by NostalgiaRadioTime - 12-27-2018, 01:00 PM
RE: Zenith 10-s-464 - by Phlogiston - 12-27-2018, 01:11 PM
RE: Zenith 10-s-464 - by Tucker - 12-28-2018, 09:07 PM
RE: Zenith 10-s-464 - by Tucker - 12-29-2018, 02:53 PM
RE: Zenith 10-s-464 - by KCMike - 12-29-2018, 03:28 PM
RE: Zenith 10-s-464 - by Tucker - 12-29-2018, 05:41 PM
RE: Zenith 10-s-464 - by Tucker - 12-30-2018, 01:26 PM
New member
Philco 630csx power cord
New member
There are currently 2650 online users. [Complete List]
» 2 Member(s) | 2648 Guest(s)
