Zenith 10-s-464
Had a 12S370 that did the same thing... Needed the band switch cleaned again... Found that if I move the band switch through all the positions a couple times a week even if its not turned on, it doesnt have the issue anymore...
Zenith 10-s-464 - by Tucker - 12-26-2018, 08:13 AM
RE: Zenith 10-s-464 - by morzh - 12-26-2018, 09:49 AM
RE: Zenith 10-s-464 - by Tucker - 12-26-2018, 10:05 PM
RE: Zenith 10-s-464 - by sdradioman - 12-27-2018, 08:42 AM
RE: Zenith 10-s-464 - by NostalgiaRadioTime - 12-27-2018, 01:00 PM
RE: Zenith 10-s-464 - by Phlogiston - 12-27-2018, 01:11 PM
RE: Zenith 10-s-464 - by Tucker - 12-28-2018, 09:07 PM
RE: Zenith 10-s-464 - by Tucker - 12-29-2018, 02:53 PM
RE: Zenith 10-s-464 - by KCMike - 12-29-2018, 03:28 PM
RE: Zenith 10-s-464 - by Tucker - 12-29-2018, 05:41 PM
RE: Zenith 10-s-464 - by Tucker - 12-30-2018, 01:26 PM
New member
Philco 630csx power cord
New member
There are currently 3408 online users. [Complete List]
» 3 Member(s) | 3405 Guest(s)
