Handy Ohm's Law cheat sheet
Chuck- Funny thing is, I just came across this same diagram in my RCA Radio and TV course from the 1950's about a day ago! Interesting coincidence Icon_smile Thanks for posting it- I may print this one out for keeping handy at the workshop.
Scott
Old Cars, Old Radios, Old Pipes and Young Women... What more is there?
Handy Ohm's Law cheat sheet - by Chuck Schwark - 02-10-2006, 01:51 PM
[No subject] - by Robbie Roberts - 02-10-2006, 02:00 PM
Ohm's :aw - by Ernst - 02-10-2006, 08:53 PM
[No subject] - by Guest - 04-25-2006, 08:10 PM
There are currently 6347 online users. [Complete List]
» 2 Member(s) | 6345 Guest(s)
