Eico 324 Signal Generator Hookup and Usage
(12-29-2018, 12:54 PM)35Z5 Wrote:  I'd be rechecking my work and set operation.
In 50+ years I'm yet to see a radio so badly out of alignment that it won't at least receive locals.
I agree. If all the parts replaced during the restoration were good quality and within tolerance, the set should at least work reasonably well and require very little tweaking.
Did it work before you started?
RE: Eico 324 Signal Generator Hookup and Usage - by John Bartley - 12-29-2018, 07:35 PM
Eico 232 VTVM Schematic
There are currently 9072 online users. [Complete List]
» 1 Member(s) | 9071 Guest(s)
