Philco 38-17F Variant - another undocumented set
Hi Ron,
I've just recently been bit by the radio restoration bug. I really enjoy your website and the Philco Phorum. I was trying to lookup a model in the gallery and was unable to locate it, so I did a search in the Phorum and behold there it is. Below is a picture. It is a 5 tube setup and is marked as a model 17 code 125. I'm curious, would this be a worthwhile restoration project? With only 5 tubes on the chassis what would the sound quality be? Thanks for your input. I wish I would have read more before beginning the 41-300 I'm in the middle of now, The wiring is extremely time consuming, but can't wait to hear how it sounds when it's complete.
Note from site admin: Sorry, but the photo which was attached to this post is no longer available.
Happily back in Illinois..not.
Re: Philco 38-17F Variant - another undocumented set - by Glenn Roberts - 10-18-2010, 05:19 AM
There are currently 10541 online users. [Complete List]
» 2 Member(s) | 10539 Guest(s)
