Magnavox 70s console
Ok, got back to work on the Maggy and did some testing on the ferrite loopstick antenna. I took capacitance measurements of the tuning gang in parallel with the antenna after disconnecting everything around it. I took measurements at 550kz, 1 MHz, and 1.6 MHz on the dial assuming the dial is accurate. Then using some math, calculated what the inductance the antenna should be to resonate at these frequencies. What I found was the inductance calculated out to be approx. 435 micro-henries. When I measured the antenna, it turned out to be 475 micro-henries, so I am thinking we are in the ball park close enough considering the accuracy of the settings on the dial. This exonerates the primary of the antenna for me. I don't know what the secondary should be but I find it strange that the antenna would be defective being that the windings are only one layer, what could go wrong! So I retested all the components in the RF stage and nothing. I ended up experimenting with changing the bias voltages on the transistor by changing resistor values hoping to get more gain and viola, success! I don't know how good of a performer this unit was in the day but it now plays decently. Now onto the FM where I believe the oscillator is not running!
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
Magnavox 70s console - by 462ron - 12-23-2018, 01:20 PM
RE: Magnavox 70s console - by Radioroslyn - 12-23-2018, 01:35 PM
RE: Magnavox 70s console - by 462ron - 12-23-2018, 02:16 PM
RE: Magnavox 70s console - by Radioroslyn - 12-23-2018, 02:46 PM
RE: Magnavox 70s console - by 462ron - 12-23-2018, 03:32 PM
RE: Magnavox 70s console - by 462ron - 12-23-2018, 03:43 PM
RE: Magnavox 70s console - by Arran - 12-23-2018, 04:43 PM
RE: Magnavox 70s console - by 462ron - 12-23-2018, 05:26 PM
RE: Magnavox 70s console - by 462ron - 12-30-2018, 11:41 AM
RE: Magnavox 70s console - by rocketeer - 01-08-2019, 11:56 PM
RE: Magnavox 70s console - by 462ron - 01-09-2019, 12:52 AM
RE: Magnavox 70s console - by rocketeer - 01-09-2019, 05:19 PM
RE: Magnavox 70s console - by 462ron - 01-09-2019, 08:42 PM
RE: Magnavox 70s console - by rocketeer - 01-09-2019, 09:15 PM
RE: Magnavox 70s console - by 462ron - 01-10-2019, 01:39 AM
RE: Magnavox 70s console - by 462ron - 01-22-2019, 03:36 PM
RE: Magnavox 70s console - by morzh - 01-23-2019, 12:24 PM
RE: Magnavox 70s console - by 462ron - 01-23-2019, 02:58 PM
RE: Magnavox 70s console - by morzh - 01-23-2019, 07:18 PM
RE: Magnavox 70s console - by 462ron - 01-24-2019, 01:28 AM
RE: Magnavox 70s console - by morzh - 01-24-2019, 09:12 AM
RE: Magnavox 70s console - by 462ron - 01-24-2019, 09:26 AM
RE: Magnavox 70s console - by 462ron - 01-24-2019, 01:49 PM
RE: Magnavox 70s console - by morzh - 01-24-2019, 02:19 PM
RE: Magnavox 70s console - by 462ron - 01-24-2019, 03:47 PM
RE: Magnavox 70s console - by morzh - 01-24-2019, 04:35 PM
RE: Magnavox 70s console - by 462ron - 01-25-2019, 03:11 PM
RE: Magnavox 70s console - by morzh - 01-25-2019, 05:45 PM
RE: Magnavox 70s console - by 462ron - 01-26-2019, 01:40 AM
RE: Magnavox 70s console - by morzh - 01-26-2019, 07:37 PM
RE: Magnavox 70s console - by 462ron - 01-26-2019, 09:13 PM
RE: Magnavox 70s console - by morzh - 01-27-2019, 12:58 PM
RE: Magnavox 70s console - by 462ron - 01-27-2019, 02:51 PM
RE: Magnavox 70s console - by morzh - 01-27-2019, 03:27 PM
RE: Magnavox 70s console - by Arran - 01-28-2019, 03:56 AM
RE: Magnavox 70s console - by 462ron - 01-28-2019, 02:21 PM
RE: Magnavox 70s console - by morzh - 01-28-2019, 02:24 PM
RE: Magnavox 70s console - by 462ron - 01-28-2019, 02:31 PM
RE: Magnavox 70s console - by morzh - 01-28-2019, 02:34 PM
RE: Magnavox 70s console - by 462ron - 01-30-2019, 10:44 PM
RE: Magnavox 70s console - by morzh - 01-30-2019, 11:27 PM
RE: Magnavox 70s console - by 462ron - 01-30-2019, 11:54 PM
RE: Magnavox 70s console - by morzh - 01-31-2019, 12:08 AM
RE: Magnavox 70s console - by 462ron - 01-31-2019, 12:16 AM
RE: Magnavox 70s console - by Ron Ramirez - 01-31-2019, 07:57 AM
RE: Magnavox 70s console - by morzh - 01-31-2019, 10:12 AM
RE: Magnavox 70s console - by 462ron - 01-31-2019, 11:02 AM
RE: Magnavox 70s console - by morzh - 01-31-2019, 12:05 PM
RE: Magnavox 70s console - by 462ron - 02-01-2019, 12:19 AM
RE: Magnavox 70s console - by morzh - 02-01-2019, 11:02 AM
RE: Magnavox 70s console - by 462ron - 02-01-2019, 05:35 PM
