Philco 16B
Hi Joe
Yes, and yes.
Let us know how it goes putting the veneer on the top/sides, OK? It seems as if it would be easy to apply veneer with the grain running vertically, but not so horizontally (front to back).
Philco 16B - by w4rtc - 10-18-2010, 02:54 PM
Re: Philco 16B - by Ron Ramirez - 10-18-2010, 05:34 PM
Re: Philco 16B - by w4rtc - 10-20-2010, 02:11 PM
Re: Philco 16B - by Ron Ramirez - 10-20-2010, 02:20 PM
Re: Philco 16B - by DeckApe - 10-20-2010, 04:12 PM
Re: Philco 16B - by Ron Ramirez - 10-20-2010, 05:11 PM
Re: Philco 16B - by w4rtc - 10-20-2010, 07:16 PM
Re: Philco 16B - by Ron Ramirez - 10-20-2010, 07:26 PM
Re: Philco 16B - by Steve Davis - 10-21-2010, 10:11 PM
Re: Philco 16B - by w4rtc - 10-21-2010, 11:09 PM
There are currently 8698 online users. [Complete List]
» 2 Member(s) | 8696 Guest(s)
