Christmas '18 Project: The Fisher FM-50-B
So I replaced the 8 uF electrolytic late morning on Christmas Day.
Today, I returned to the FM-50-B. I recapped the WX MPX decoder and reinstalled it in the tuner.
Then I removed the main electrolytic capacitor can (four section 40 uF), only to find that....I have no 40 uF electrolytics in stock.
So this one will be set aside for a while. I'll order some electrolytics and on the next "good" weekend, I'll restuff the can, install it and we'll see at that point if it works, or not.
Eico 232 VTVM Schematic
There are currently 9238 online users. [Complete List]
» 1 Member(s) | 9237 Guest(s)
