Restoring my 46 1226 122
I'm pretty sure I won't have that issue, as my model has the electromagnetic speaker which works as a choke, which is probably what that resistor of yours was replacing.
So, I dug in and did some cleaning yesterday, and it looks like everything has a really thick coating of cigarette smoke on it. Are there any suggestions for cleaning that kind of crud off, or is it just a matter of doing the manual labor?
Will warm water and soap get it off the tubes? I assume I would try to not get any water in the base, but I'm reluctant to try this unless all else fails.
I did some cleaning of the record player, and the yellow smoke crud is thick on everything, but cleaned off the idler wheel nicely. The wheel is hard but round, so I might try to modify it to hold a silicone o-ring instead of having it resurfaced.
Restoring my 46 1226 122 - by Mutantmoose - 12-17-2018, 08:31 PM
RE: Restoring my 46 1226 122 - by Radioroslyn - 12-18-2018, 04:44 PM
RE: Restoring my 46 1226 122 - by Mutantmoose - 12-18-2018, 07:46 PM
RE: Restoring my 46 1226 122 - by jcassity - 12-18-2018, 09:57 PM
RE: Restoring my 46 1226 122 - by Mutantmoose - 12-18-2018, 11:56 PM
RE: Restoring my 46 1226 122 - by jcassity - 12-19-2018, 09:41 AM
RE: Restoring my 46 1226 122 - by Mutantmoose - 12-31-2018, 03:54 PM
RE: Restoring my 46 1226 122 - by jcassity - 01-01-2019, 12:07 PM
RE: Restoring my 46 1226 122 - by Mutantmoose - 01-20-2019, 12:46 PM
91H Code 126 Restore
There are currently 3943 online users. [Complete List]
» 3 Member(s) | 3940 Guest(s)
