Philco 39-25T
Radio Daze makes the white and black dial reproduction.  Same dial is used on the 39-30 and 39-25.
There is a metal escutcheon that goes over the top of the area for the dial.  The escutcheon holds the station labels in some slots.  New buttons are available from Renovated Radios.
This is what I started with...
[Image: https://www.dropbox.com/s/q98egefokc81ad....jpg?raw=1]
Here's the best close up of the escutcheon I have:
[Image: https://www.dropbox.com/s/zs4gzs6la1aohd....jpg?raw=1]
The escutcheon is not reproduced so you will have to find one on a donor chassis. Perhaps an ad in the wanted section here and keep an eye on the ebay offerings.
The buttons are retained by sliding onto the metal slats seen in this photo with the small rubber piece and circle on the slat.  I never found a replacement for the rubber piece but it works fine without it.  the open end of the slat is to the right and unseen in this photo.
[Image: https://www.dropbox.com/s/iezjbwnnmsuo8i....jpg?raw=1]
some notes and threads on the restoration can be found in the link in the signature below
Philco 39-25T - by Chris h - 01-01-2019, 11:47 PM
RE: Philco 39-25T - by klondike98 - 01-02-2019, 10:46 AM
RE: Philco 39-25T - by Nathan Slingerland - 01-02-2019, 10:59 AM
RE: Philco 39-25T - by klondike98 - 01-02-2019, 11:59 AM
RE: Philco 39-25T - by Phlogiston - 01-02-2019, 01:59 PM
RE: Philco 39-25T - by Chris h - 01-02-2019, 11:57 PM
RE: Philco 39-25T - by Nathan Slingerland - 01-03-2019, 12:14 AM
