Philco 39-25T
One small addition to Bob's very detailed reply - reproduction dial 'glass' (plastic in this case) is available during from https://dialcover.com/
That's just the clear part.
Philco 39-25T - by Chris h - 01-01-2019, 11:47 PM
RE: Philco 39-25T - by klondike98 - 01-02-2019, 10:46 AM
RE: Philco 39-25T - by Nathan Slingerland - 01-02-2019, 10:59 AM
RE: Philco 39-25T - by klondike98 - 01-02-2019, 11:59 AM
RE: Philco 39-25T - by Phlogiston - 01-02-2019, 01:59 PM
RE: Philco 39-25T - by Chris h - 01-02-2019, 11:57 PM
RE: Philco 39-25T - by Nathan Slingerland - 01-03-2019, 12:14 AM
