ZenithT2518
Most of the failures I have seen have not been from the heaters open. The 12DT8 has a internal shield grounded to pin 9 from some reason the shield fails and will short the tube out. The 14GT8 and 19T8 just seem to fail without any warning. The 12DT8 can be replaced with a 17EW8 without  changes to the tube socket. A 12AT7 can be used as a sub for the 12DT8 IF YOU MAKE A MOD TO PIN 9 of the tube socket or remove pin 9 from the tube. 12AT7 does not have a internal shield to ground on pin 9 but a tap to the heater so you have a dead short to ground your nice new tube will go poof!!! I have done the mod to the tube socket on 2 sets been happy with the results
ZenithT2518 - by Paul Philco322 - 11-29-2018, 01:08 PM
RE: ZenithT2518 - by Paul Philco322 - 01-02-2019, 08:55 AM
RE: ZenithT2518 - by David - 01-02-2019, 09:24 AM
RE: ZenithT2518 - by Jayce - 01-02-2019, 12:20 PM
RE: ZenithT2518 - by Phlogiston - 01-02-2019, 02:19 PM
RE: ZenithT2518 - by David - 01-02-2019, 02:45 PM
RE: ZenithT2518 - by mikethedruid - 01-02-2019, 02:57 PM
RE: ZenithT2518 - by Paul Philco322 - 01-02-2019, 09:37 PM
RE: ZenithT2518 - by Eliot Ness - 01-03-2019, 08:22 PM
RE: ZenithT2518 - by Paul Philco322 - 01-03-2019, 10:04 PM
RE: ZenithT2518 - by Ron Ramirez - 01-04-2019, 07:21 AM
RE: ZenithT2518 - by Philco444 - 01-14-2019, 03:15 PM
RE: ZenithT2518 - by Arran - 01-14-2019, 06:08 PM
RE: ZenithT2518 - by KCMike - 01-14-2019, 07:00 PM
New member
Philco 630csx power cord
New member
There are currently 4060 online users. [Complete List]
» 1 Member(s) | 4059 Guest(s)
