Problems in a little PT2
Wouldn't worry about the IF coil more than likely the 47K resistor has drifted some but is of little consequence. If I had it apart to replace the rubber wire I'd check and replace. But the 4 ohm/80 ohm resistor is an issue. 5w is ok total dissipation is 1.8w, I generally go X3. Dissipation is less for the 40 ohm (abt 1 w), it's job is to stop the lamp from burning out from the ac inrush.
PT2 tuning capacitor - by elfiself - 01-02-2019, 10:47 PM
RE: Problems in a little PT2 - by Ron Ramirez - 01-03-2019, 03:54 PM
RE: Problems in a little PT2 - by elfiself - 01-04-2019, 03:45 PM
RE: Problems in a little PT2 - by Radioroslyn - 01-04-2019, 04:20 PM
RE: Problems in a little PT2 - by elfiself - 01-04-2019, 05:06 PM
RE: PT2 tuning capacitor - by gregb - 01-02-2019, 10:50 PM
RE: PT2 tuning capacitor - by elfiself - 01-02-2019, 11:26 PM
problems in a little PT2 - by elfiself - 01-03-2019, 02:11 PM
RE: PT2 tuning capacitor - by Radioroslyn - 01-03-2019, 02:49 PM
RE: PT2 tuning capacitor - by sam - 01-03-2019, 02:49 PM
Problems in a little PT2 - by elfiself - 01-03-2019, 03:49 PM
91H Code 126 Restore
