Philco 610
Hi Ron,
Thanks for the reply! I'm not sure if there were more than one grille cloth patterns used on the 610, but the original from my 610 looks different from that one.
http://s908.photobucket.com/albums/ac283...e%20cloth/
I wish they had better photos for better grille cloth selection. This one is similar, but not the same as a Crosley pattern I recently ordered. I was thinking that pattern 12, 13, or 52 may be close, but I can't tell by the pics there. Any advice would be most helpful! Thanks again.
Tim
Philco 610 - by Timaaay - 11-18-2010, 12:04 PM
Re: Philco 610 - by Ron Ramirez - 11-18-2010, 09:21 PM
Re: Philco 610 - by Timaaay - 11-20-2010, 01:48 PM
Re: Philco 610 - by Ron Ramirez - 11-20-2010, 04:05 PM
