Philco Model 80
Not only that, Don, but you should also replace the grid leak resistor which is mounted on top of the IF transformer with a new 2 meg, 1/2 watt resistor.
The best way I have found to replace this part is to clip the resistor leads up against the body of the resistor and then use those wire lead stubs to connect the new resistor. Trying to unsolder the original at the terminals on the IF transformer can damage the transformer.
Philco Model 80 - by gregb - 01-05-2019, 08:15 AM
RE: Philco Model 80 - by 45philcodon - 01-05-2019, 05:36 PM
RE: Philco Model 80 - by Radioroslyn - 01-05-2019, 05:46 PM
RE: Philco Model 80 - by gregb - 01-05-2019, 07:03 PM
RE: Philco Model 80 - by amptramp - 01-05-2019, 11:36 PM
RE: Philco Model 80 - by 462ron - 01-06-2019, 11:54 AM
RE: Philco Model 80 - by 45philcodon - 01-06-2019, 04:17 PM
RE: Philco Model 80 - by gregb - 01-06-2019, 10:24 PM
RE: Philco Model 80 - by Ron Ramirez - 01-07-2019, 05:58 AM
RE: Philco Model 80 - by 45philcodon - 01-08-2019, 06:09 PM
RE: Philco Model 80 - by rfeenstra - 01-09-2019, 12:40 AM
RE: Philco Model 80 - by Ron Ramirez - 01-09-2019, 07:09 AM
RE: Philco Model 80 - by mark123 - 01-10-2019, 11:13 AM
RE: Philco Model 80 - by rfeenstra - 01-10-2019, 01:36 PM
91H Code 126 Restore
There are currently 4090 online users. [Complete List]
» 1 Member(s) | 4089 Guest(s)
