Philco 16B
I don't recommend that, because then you have to fill the cut with wood putty, which will show afterwards. (I know because I tried, and it didn't work. Then I had to fill the cut with wood putty.)
However, I discovered a trick today: I had bought an old iron at a yard sale this past weekend for 50 cents. I purchased this specifically to iron veneer onto substrate, in order to speed the setting time. I learned this from watching a video made by "Hagstar" John H.:
http://hagstar.phanfare.com/slideshow.as...id=3128328
I've been slacking off on my studies this week to work on a Philco 44B cabinet, as mentioned previously. The cabinet was in really bad shape, and the grillework was delaminating badly. I used my yard sale iron to help glue the veneer back onto the front panel and front arch.
Anyway, figuring I had nothing to lose, I decided to try using the iron on the side of the cabinet where some air bubbles were showing.
It worked! It seems to have made the air bubbles go down.
I turned the iron temperature all the way up when using it on the cabinet. The iron does not scorch or burn the wood if you work carefully.
Philco 16B - by w4rtc - 10-18-2010, 02:54 PM
Re: Philco 16B - by Ron Ramirez - 10-18-2010, 05:34 PM
Re: Philco 16B - by w4rtc - 10-20-2010, 02:11 PM
Re: Philco 16B - by Ron Ramirez - 10-20-2010, 02:20 PM
Re: Philco 16B - by DeckApe - 10-20-2010, 04:12 PM
Re: Philco 16B - by Ron Ramirez - 10-20-2010, 05:11 PM
Re: Philco 16B - by w4rtc - 10-20-2010, 07:16 PM
Re: Philco 16B - by Ron Ramirez - 10-20-2010, 07:26 PM
Re: Philco 16B - by Steve Davis - 10-21-2010, 10:11 PM
Re: Philco 16B - by w4rtc - 10-21-2010, 11:09 PM
There are currently 10089 online users. [Complete List]
» 1 Member(s) | 10088 Guest(s)
