37-690 rectifier flash / arc
My personal preference of power-up:
1. Without any tubes, check the transformer for the proper output.
2. After full recap, repeat.
3. With all tubes in and speaker connected power from Variac via isolation xfmr and see the DC, a reasonable level.
4. With no Variac, power up and see the DC rise fully over 10 seconds or so, and then droop a little.
5. Wait with your finger on Off switch. If in a minute nothing bad happens, proceed with full check.
37-690 rectifier flash / arc - by mr.jukebox - 01-10-2019, 07:23 PM
RE: 37-690 rectifier flash / arc - by Ron Ramirez - 01-10-2019, 07:47 PM
RE: 37-690 rectifier flash / arc - by Phlogiston - 01-10-2019, 07:54 PM
RE: 37-690 rectifier flash / arc - by mr.jukebox - 01-10-2019, 08:05 PM
RE: 37-690 rectifier flash / arc - by Ron Ramirez - 01-10-2019, 08:06 PM
RE: 37-690 rectifier flash / arc - by morzh - 01-10-2019, 09:16 PM
RE: 37-690 rectifier flash / arc - by tbone - 01-12-2019, 07:32 AM
RE: 37-690 rectifier flash / arc - by 35Z5 - 01-12-2019, 06:25 PM
91H Code 126 Restore
There are currently 3269 online users. [Complete List]
» 1 Member(s) | 3268 Guest(s)
