Eico 324 Drop-out issue
You might try using an ohmmeter and measure the resistance of the tuning cap (should be open always) and see if it shorts at those knob locations in questions.
With out power of course.......
Eico 324 Drop-out issue - by Greggshere - 01-11-2019, 02:15 PM
RE: Eico 324 Drop-out issue - by bakerm - 01-11-2019, 02:28 PM
RE: Eico 324 Drop-out issue - by morzh - 01-11-2019, 08:43 PM
RE: Eico 324 Drop-out issue - by Greggshere - 01-11-2019, 08:58 PM
RE: Eico 324 Drop-out issue - by Chas - 01-11-2019, 09:32 PM
RE: Eico 324 Drop-out issue - by morzh - 01-11-2019, 11:17 PM
RE: Eico 324 Drop-out issue - by Greggshere - 01-12-2019, 01:24 AM
RE: Eico 324 Drop-out issue - by Phlogiston - 01-12-2019, 12:50 PM
RE: Eico 324 Drop-out issue - by Greggshere - 01-13-2019, 02:45 AM
Eico 232 VTVM Schematic
There are currently 5411 online users. [Complete List]
» 1 Member(s) | 5410 Guest(s)
