Eico 324 Drop-out issue
Hey morzh, I left a few words out, sorry about that. I used the 1N4007 diode and a 2.4K resistor and two .22 electrolytic caps to replace the selenium rectifier. (I also said silicon rectifier). Duh!
Gregg Icon_thumbup
Eico 324 Drop-out issue - by Greggshere - 01-11-2019, 02:15 PM
RE: Eico 324 Drop-out issue - by bakerm - 01-11-2019, 02:28 PM
RE: Eico 324 Drop-out issue - by morzh - 01-11-2019, 08:43 PM
RE: Eico 324 Drop-out issue - by Greggshere - 01-11-2019, 08:58 PM
RE: Eico 324 Drop-out issue - by Chas - 01-11-2019, 09:32 PM
RE: Eico 324 Drop-out issue - by morzh - 01-11-2019, 11:17 PM
RE: Eico 324 Drop-out issue - by Greggshere - 01-12-2019, 01:24 AM
RE: Eico 324 Drop-out issue - by Phlogiston - 01-12-2019, 12:50 PM
RE: Eico 324 Drop-out issue - by Greggshere - 01-13-2019, 02:45 AM
