Philco 38-17F Variant - another undocumented set
The same was done with auto radios ! I have a 1938 Chevrolet radio , it has a head control that replaces the ash tray on a 1939 Chevrolet , for some reason there was an over stock of 38 radios these head controls help dealer sell out of the 38 radio installing them in 1939 cars, There was a large number of 38 Chevy head controls showing up a auto flea matkets some years back, this may be the reason.
Re: Philco 38-17F Variant - another undocumented set - by BILL - 10-21-2010, 11:30 AM
There are currently 10547 online users. [Complete List]
» 2 Member(s) | 10545 Guest(s)
