Zenith 12H090
#31
Back to the radio bench in 2019!
Picking up where I left off, the tone switch bank - which is on another harness, needed all wires replaced. Each one was desoldered, and used to pull a new length of wire through the shielding braid. Most of these wires terminate at a board with capacitors mounted on it... and I didn't have all the values, so wires were tacked on until I can do the caps one-by one. This is a very cramped area of the radio, and it made for slow work.
On the audio power amp/PSU, I got the 50 mfd + 50 mfd cap restuffed and the end crimped over. That chassis is almost finished, aside from a couple of caps that, again, I was missing the correct values.
Good progress... And progress on other projects for the HiFi...
Zenith 12H090 - by EdHolland - 05-27-2018, 03:11 AM
RE: Zenith 12H090 - by morzh - 05-27-2018, 11:30 AM
RE: Zenith 12H090 - by EdHolland - 05-27-2018, 07:54 PM
RE: Zenith 12H090 - by morzh - 05-27-2018, 11:14 PM
RE: Zenith 12H090 - by EdHolland - 05-29-2018, 01:51 PM
RE: Zenith 12H090 - by Electrothaumaturgist - 05-30-2018, 02:26 PM
RE: Zenith 12H090 - by morzh - 05-30-2018, 04:51 PM
RE: Zenith 12H090 - by Electrothaumaturgist - 05-30-2018, 06:26 PM
RE: Zenith 12H090 - by Arran - 05-31-2018, 04:42 AM
RE: Zenith 12H090 - by EdHolland - 05-31-2018, 04:08 PM
RE: Zenith 12H090 - by Electrothaumaturgist - 06-01-2018, 01:41 AM
RE: Zenith 12H090 - by Arran - 06-01-2018, 02:15 AM
RE: Zenith 12H090 - by Electrothaumaturgist - 06-01-2018, 03:39 AM
RE: Zenith 12H090 - by morzh - 06-01-2018, 07:55 AM
RE: Zenith 12H090 - by EdHolland - 06-01-2018, 12:43 PM
RE: Zenith 12H090 - by Electrothaumaturgist - 06-01-2018, 03:31 PM
RE: Zenith 12H090 - by Arran - 06-02-2018, 03:06 AM
RE: Zenith 12H090 - by Electrothaumaturgist - 06-02-2018, 05:48 AM
RE: Zenith 12H090 - by EdHolland - 10-25-2018, 11:51 PM
RE: Zenith 12H090 - by Arran - 10-27-2018, 04:09 PM
RE: Zenith 12H090 - by jcassity - 10-28-2018, 07:57 PM
RE: Zenith 12H090 - by EdHolland - 12-02-2018, 12:44 PM
RE: Zenith 12H090 - by EdHolland - 12-03-2018, 03:03 AM
RE: Zenith 12H090 - by EdHolland - 12-05-2018, 03:00 PM
RE: Zenith 12H090 - by EdHolland - 12-09-2018, 09:58 PM
RE: Zenith 12H090 - by Ron Ramirez - 12-09-2018, 11:17 PM
RE: Zenith 12H090 - by Arran - 12-10-2018, 05:34 AM
RE: Zenith 12H090 - by morzh - 12-10-2018, 09:20 AM
RE: Zenith 12H090 - by EdHolland - 12-11-2018, 02:05 PM
RE: Zenith 12H090 - by EdHolland - 12-16-2018, 11:45 PM
RE: Zenith 12H090 - by EdHolland - 01-13-2019, 09:37 PM
RE: Zenith 12H090 - by EdHolland - 01-20-2019, 11:20 PM
RE: Zenith 12H090 - by EdHolland - 01-27-2019, 10:35 PM
RE: Zenith 12H090 - by EdHolland - 02-01-2019, 05:06 PM
RE: Zenith 12H090 - by EdHolland - 02-02-2019, 10:26 PM
RE: Zenith 12H090 - by jcassity - 02-03-2019, 01:47 PM
RE: Zenith 12H090 - by EdHolland - 02-03-2019, 05:56 PM
RE: Zenith 12H090 - by EdHolland - 02-03-2019, 07:34 PM
RE: Zenith 12H090 - by jcassity - 02-04-2019, 11:55 AM
RE: Zenith 12H090 - by EdHolland - 02-04-2019, 03:29 PM
RE: Zenith 12H090 - by EdHolland - 02-08-2019, 02:37 PM
RE: Zenith 12H090 - by EdHolland - 02-09-2019, 11:17 PM
RE: Zenith 12H090 - by morzh - 02-10-2019, 11:19 AM
RE: Zenith 12H090 - by EdHolland - 02-11-2019, 04:04 PM
RE: Zenith 12H090 - by EdHolland - 02-12-2019, 01:27 PM
RE: Zenith 12H090 - by EdHolland - 02-18-2019, 02:36 PM
RE: Zenith 12H090 - by EdHolland - 02-23-2019, 03:17 AM
RE: Zenith 12H090 - by OldRestorer - 02-23-2019, 08:14 AM
RE: Zenith 12H090 - by EdHolland - 02-23-2019, 07:17 PM
RE: Zenith 12H090 - by EdHolland - 02-23-2019, 07:34 PM
RE: Zenith 12H090 - by EdHolland - 02-23-2019, 09:10 PM
RE: Zenith 12H090 - by OldRestorer - 02-24-2019, 03:02 PM
RE: Zenith 12H090 - by EdHolland - 02-25-2019, 06:34 PM
RE: Zenith 12H090 - by jcassity - 02-25-2019, 07:31 PM
RE: Zenith 12H090 - by tbone - 02-25-2019, 08:31 PM
RE: Zenith 12H090 - by Arran - 02-26-2019, 06:55 AM
RE: Zenith 12H090 - by EdHolland - 02-26-2019, 09:15 PM
RE: Zenith 12H090 - by OldRestorer - 03-19-2019, 01:01 PM
RE: Zenith 12H090 - by EdHolland - 03-19-2019, 09:36 PM
RE: Zenith 12H090 - by EdHolland - 05-26-2019, 12:46 AM
RE: Zenith 12H090 - by morzh - 05-26-2019, 08:32 AM
RE: Zenith 12H090 - by EdHolland - 05-26-2019, 10:48 AM
RE: Zenith 12H090 - by Eliot Ness - 05-26-2019, 11:11 AM
RE: Zenith 12H090 - by EdHolland - 05-26-2019, 09:22 PM
RE: Zenith 12H090 - by morzh - 05-27-2019, 10:43 AM
RE: Zenith 12H090 - by EdHolland - 05-27-2019, 11:48 AM
RE: Zenith 12H090 - by EdHolland - 01-12-2021, 08:45 PM
RE: Zenith 12H090 - by Arran - 01-13-2021, 12:31 AM
RE: Zenith 12H090 - by EdHolland - 01-13-2021, 11:33 AM
RE: Zenith 12H090 - by EdHolland - 01-16-2021, 09:58 PM
RE: Zenith 12H090 - by EdHolland - 01-21-2021, 08:25 PM
Users browsing this thread: 14 Guest(s)
Philco 91 Tuning Condenser
There are currently 10157 online users. [Complete List]
» 3 Member(s) | 10154 Guest(s)
