Philco 16B
Another good option is the paper backed veneer. Paper backed veneer is available 48 by 96 inch sheets, so you can run the grain from front to back. I have purchased veneer from this fellow on Ebay and have received good service http://cgi.ebay.com/120533411147 A sheet this size will do several radios, so you might be able to share with someone else.
M R Radios   C M Tubes
Philco 16B - by w4rtc - 10-18-2010, 02:54 PM
Re: Philco 16B - by Ron Ramirez - 10-18-2010, 05:34 PM
Re: Philco 16B - by w4rtc - 10-20-2010, 02:11 PM
Re: Philco 16B - by Ron Ramirez - 10-20-2010, 02:20 PM
Re: Philco 16B - by DeckApe - 10-20-2010, 04:12 PM
Re: Philco 16B - by Ron Ramirez - 10-20-2010, 05:11 PM
Re: Philco 16B - by w4rtc - 10-20-2010, 07:16 PM
Re: Philco 16B - by Ron Ramirez - 10-20-2010, 07:26 PM
Re: Philco 16B - by Steve Davis - 10-21-2010, 10:11 PM
Re: Philco 16B - by w4rtc - 10-21-2010, 11:09 PM
There are currently 8682 online users. [Complete List]
» 2 Member(s) | 8680 Guest(s)
