Echophone S-4 Help Wanted
Hm-m-m. Voltages did indeed increase, but the problem is that the B voltage is already too high. The 245 plate should be some between 150v and 250v. It's 345v at normal line voltage. Except for filament voltages, a quick check seemed to show all other tube voltages were too high as well.
Echophone S-4 Help Wanted - by Winky Dink - 01-16-2019, 01:31 PM
RE: Echophone S-4 Help Wanted - by Steve Davis - 01-16-2019, 03:34 PM
RE: Echophone S-4 Help Wanted - by Winky Dink - 01-17-2019, 01:41 AM
RE: Echophone S-4 Help Wanted - by Steve Davis - 01-17-2019, 01:32 PM
RE: Echophone S-4 Help Wanted - by Winky Dink - 01-17-2019, 01:47 PM
RE: Echophone S-4 Help Wanted - by Phlogiston - 01-17-2019, 04:19 PM
RE: Echophone S-4 Help Wanted - by Winky Dink - 01-17-2019, 05:40 PM
RE: Echophone S-4 Help Wanted - by Winky Dink - 01-21-2019, 07:40 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
There are currently 2554 online users. [Complete List]
» 3 Member(s) | 2551 Guest(s)
