Heathkit GD-1B
Ok Back together.. Seems to work Well a Little bit.. It will Osc and put out frequencies.. Quite Stable
But When I turn the Sensitivity control all the way Clockwise I can only get it to Read Grid current About 1/2 way Between pegged to left and 0..
Voltages measured..
115 DC after Rectifier
110 DC After 1K ohm resistor
Pin1 of tube 81 Volts DC
Pin 2 of tube -15 Volts
Any clue why almost no grid current on meter??
Skip
Heathkit GD-1B - by vecher - 12-31-2018, 06:37 PM
RE: Heathkit GD-1B - by gregb - 12-31-2018, 06:44 PM
RE: Heathkit GD-1B - by Radioroslyn - 12-31-2018, 06:58 PM
RE: Heathkit GD-1B - by vecher - 12-31-2018, 06:59 PM
RE: Heathkit GD-1B - by vecher - 12-31-2018, 07:02 PM
RE: Heathkit GD-1B - by Steve Davis - 12-31-2018, 07:56 PM
RE: Heathkit GD-1B - by Steve Davis - 12-31-2018, 07:57 PM
RE: Heathkit GD-1B - by Radioroslyn - 12-31-2018, 08:03 PM
RE: Heathkit GD-1B - by vecher - 01-01-2019, 10:09 PM
RE: Heathkit GD-1B - by Chas - 01-01-2019, 11:17 PM
RE: Heathkit GD-1B - by vecher - 01-02-2019, 12:11 AM
RE: Heathkit GD-1B - by Radioroslyn - 01-03-2019, 11:28 AM
RE: Heathkit GD-1B - by vecher - 01-09-2019, 01:46 AM
RE: Heathkit GD-1B - by Surfur - 01-17-2019, 01:46 AM
RE: Heathkit GD-1B - by Radioroslyn - 01-17-2019, 10:52 AM
RE: Heathkit GD-1B - by Surfur - 01-17-2019, 01:24 PM
RE: Heathkit GD-1B - by vecher - 01-19-2019, 12:14 AM
RE: Heathkit GD-1B - by vecher - 01-19-2019, 09:39 PM
RE: Heathkit GD-1B - by Surfur - 01-20-2019, 02:58 AM
RE: Heathkit GD-1B - by vecher - 01-20-2019, 11:10 AM
RE: Heathkit GD-1B - by vecher - 01-20-2019, 04:56 PM
RE: Heathkit GD-1B - by KCMike - 01-20-2019, 05:53 PM
RE: Heathkit GD-1B - by vecher - 01-20-2019, 08:29 PM
RE: Heathkit GD-1B - by vecher - 01-21-2019, 12:04 AM
RE: Heathkit GD-1B - by vecher - 02-15-2019, 09:17 PM
RE: Heathkit GD-1B - by EdHolland - 02-15-2019, 09:39 PM
RE: Heathkit GD-1B - by Surfur - 03-12-2019, 10:12 PM
RE: Heathkit GD-1B - by EdHolland - 03-12-2019, 11:57 PM
RE: Heathkit GD-1B - by vecher - 03-13-2019, 03:00 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 3167 online users. [Complete List]
» 2 Member(s) | 3165 Guest(s)
