Threads: 214
City: Seattle
State, Province, Country: WA
The state of cloth covered wire varies. On the 38-116 it was still pretty pliable so I left it alone. Even it's stiff I usually only replace cloth wire that has cracked or been damaged. To me stiff cloth wire that is intact isn't a problem (unlike rubber wire that is flaking of insulation).
On a 37-650 I worked on the cloth wire was in worse shape so I did replace the wires that had to be moved (e.g. going to RF sub chassis).
In replacing wires there's not only the difficulty of obtaining original looking wires but also the concern for keeping wire placement / routing the same.
Users browsing this thread: 19 Guest(s)
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
91H Code 126 Restore
Just to make it more confusing here is another model 91 schematic that doesn't show parts with dotted lines in that spot...Arran — 10:37 PM |
The wires were desoldered from the can, and the capacitors checked. All checked at 0.102 uF, which is correct.
So the c...morzh — 09:41 PM |
Yours probably then the H speaker, same as mine.morzh — 08:39 PM |
Mike;
I would like to have a look at the speaker in my model 96, but the set is packed into a corner in the basement. ...Arran — 08:04 PM |
Thanks Arran,
I'm convinced the power cord is good but have a nice repro plug for it. Would it be prudent to add a fus...RealRider — 07:28 PM |
As I was studying this schematic I was wondering what does this dotted line means? I haven't traced it out yet.
An o...RealRider — 07:22 PM |
There are currently 4094 online users. [Complete List] » 1 Member(s) | 4093 Guest(s)
