Advice for removing finish on a 37-650
DO NOT USE DCL-PH7 or DCL-PH9. The fonts are these are grossly incorrect. Why they keep selling these, I do not know...
DCL-PH8 looks incorrect on their website but what you receive will be the correct 1932-1936 (and early 1937) font.
The medium size PHILCO decal in DCL-PH1 would be a good choice for later production 1937 and 1938 model Philcos.
RE: Advice for removing finish on a 37-650 - by Ron Ramirez - 01-21-2019, 09:59 AM
