Did Philcos come in a green finish?
I recently acquired a 42-1008p in green finish.  I thought someone did a garish job of refinishing until I saw this recent listing for a Philco on craigslist.  It's a 53-1750 with the same finish.  Is the green finish on my 42-1008p a factory finish?
Did Philcos come in a green finish? - by Kestas - 01-21-2019, 10:39 AM
There are currently 10041 online users. [Complete List]
» 2 Member(s) | 10039 Guest(s)
