Zenith TO old AC plug
If this plug from 40s, I doubt 3-pin plugs were popular back then....
Zenith TO old AC plug - by morzh - 01-21-2019, 05:27 PM
RE: Zenith TO old AC plug - by EdHolland - 01-21-2019, 06:54 PM
RE: Zenith TO old AC plug - by morzh - 01-21-2019, 07:02 PM
RE: Zenith TO old AC plug - by EdHolland - 01-21-2019, 07:20 PM
RE: Zenith TO old AC plug - by morzh - 01-21-2019, 11:46 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
There are currently 2476 online users. [Complete List]
» 3 Member(s) | 2473 Guest(s)
