Zenith TO old AC plug
You'd be surprised Mike:
https://en.wikipedia.org/wiki/AC_power_p...ated_types
3 pins go as far back as 1911, with British Standard designated plug designs being defined as early as 1928. Connectors were standardised, it seems, before the actual supply was brought to a uniform specification!
Zenith TO old AC plug - by morzh - 01-21-2019, 05:27 PM
RE: Zenith TO old AC plug - by EdHolland - 01-21-2019, 06:54 PM
RE: Zenith TO old AC plug - by morzh - 01-21-2019, 07:02 PM
RE: Zenith TO old AC plug - by EdHolland - 01-21-2019, 07:20 PM
RE: Zenith TO old AC plug - by morzh - 01-21-2019, 11:46 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
There are currently 2454 online users. [Complete List]
» 3 Member(s) | 2451 Guest(s)
