My Philco 95 low boy late version
Awesome finds Jake!
It would be great if you can scan and upload the instructions and tag to the Downloads section.
Both of those items are quite rare to find now - much rarer than the radios themselves.
http://philcoradio.com/phorum/forumdisplay.php?fid=25
I'm happy to help if needed.
My Philco 95 low boy late version - by jake wells - 01-23-2019, 12:31 AM
RE: My Philco 95 low boy late version - by Nathan Slingerland - 01-23-2019, 01:29 AM
RE: My Philco 95 low boy late version - by morzh - 01-23-2019, 10:01 AM
There are currently 10235 online users. [Complete List]
» 3 Member(s) | 10232 Guest(s)
