  • 1 Vote(s) - 5 Average
Hammerlund HQ-110A
Well, It looks like it finally stabilized.. I just checked bands and all are very close.. Have NO Clue WHY..
So i just put it in cabinet and Turned off. I will check it later this evening again after warming up for an hour..
Stay Tuned>>>..
Skip
Hammerlund HQ-110A - by vecher - 01-08-2019, 06:03 PM
RE: Hammerlund HQ-110A - by Radioroslyn - 01-08-2019, 07:23 PM
RE: Hammerlund HQ-110A - by vecher - 01-08-2019, 08:14 PM
RE: Hammerlund HQ-110A - by vecher - 01-09-2019, 01:41 AM
RE: Hammerlund HQ-110A - by vecher - 01-13-2019, 11:16 PM
RE: Hammerlund HQ-110A - by mikethedruid - 01-14-2019, 05:52 AM
RE: Hammerlund HQ-110A - by vecher - 01-16-2019, 10:39 PM
RE: Hammerlund HQ-110A - by vecher - 01-17-2019, 10:53 PM
RE: Hammerlund HQ-110A - by vecher - 01-22-2019, 10:17 PM
RE: Hammerlund HQ-110A - by jcassity - 01-23-2019, 03:50 PM
RE: Hammerlund HQ-110A - by vecher - 01-23-2019, 05:46 PM
RE: Hammerlund HQ-110A - by thirtiesradio - 01-25-2019, 06:56 PM
RE: Hammerlund HQ-110A - by mikethedruid - 01-25-2019, 07:56 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
There are currently 1973 online users. [Complete List]
» 3 Member(s) | 1970 Guest(s)
