16B chassis — questions
#42
I am going to try restuffing the electrolytic caps on the power supply this weekend and wondered if the following is a bad  idea:
I plan to use to use two 16 uF in series to yield 8 uF; and 1 meg resistors for the voltage divider.
This is for caps #87 and #88 on the schematic.  In this case, the positive end connects  to the filter choke and the negative end to the center tap of the power transformer, yes?
Cap #75, on the other hand, will be a single 10 uF with the POSITIVE end to ground, right?
Thanks for any help--on my actual chassis this entire part of the circuit has been hacked out so I am trying to reconstruct it.
17b chassis — newbie questions - by mwoodruff - 12-20-2018, 09:24 AM
RE: 17b chassis — newbie questions - by morzh - 12-20-2018, 10:37 AM
RE: 16B chassis — questions - by Radioroslyn - 12-27-2018, 03:36 PM
RE: 16B chassis — questions - by mwoodruff - 12-27-2018, 05:15 PM
RE: 16B chassis — questions - by Radioroslyn - 12-27-2018, 06:08 PM
RE: 16B chassis — questions - by mwoodruff - 12-28-2018, 07:59 AM
RE: 16B chassis — questions - by Radioroslyn - 12-28-2018, 12:17 PM
RE: 16B chassis — questions - by mwoodruff - 12-31-2018, 12:39 PM
RE: 16B chassis — questions - by mwoodruff - 12-31-2018, 01:22 PM
RE: 16B chassis — questions - by Radioroslyn - 12-31-2018, 02:31 PM
RE: 16B chassis — questions - by mwoodruff - 01-07-2019, 02:03 PM
RE: 16B chassis — questions - by EdHolland - 01-07-2019, 05:39 PM
RE: 16B chassis — questions - by mwoodruff - 01-08-2019, 08:47 AM
RE: 16B chassis — questions - by mwoodruff - 01-08-2019, 12:35 PM
RE: 16B chassis — questions - by Radioroslyn - 01-08-2019, 01:35 PM
RE: 16B chassis — questions - by mwoodruff - 01-25-2019, 06:43 PM
RE: 16B chassis — questions - by Radioroslyn - 01-25-2019, 08:15 PM
RE: 16B chassis — questions - by mwoodruff - 02-22-2019, 02:17 PM
RE: 16B chassis — questions - by mwoodruff - 02-22-2019, 04:02 PM
RE: 16B chassis — questions - by mikethedruid - 02-22-2019, 05:21 PM
RE: 16B chassis — questions - by mwoodruff - 03-07-2019, 01:28 PM
RE: 16B chassis — questions - by EdHolland - 03-07-2019, 03:58 PM
RE: 16B chassis — questions - by amptramp - 03-08-2019, 09:08 AM
16b power supply questions - by mwoodruff - 12-26-2018, 12:36 PM
RE: 16b power supply questions - by Radioroslyn - 12-26-2018, 01:41 PM
16b filter bank capacitor voltages - by mwoodruff - 12-26-2018, 03:04 PM
RE: 16b restoration questions - by klondike98 - 12-26-2018, 04:51 PM
RE: 16b restoration questions - by morzh - 12-26-2018, 06:10 PM
RE: 16b restoration questions - by amptramp - 12-26-2018, 06:26 PM
RE: 16b restoration questions - by Radioroslyn - 12-26-2018, 08:41 PM
RE: 16b restoration questions - by mwoodruff - 12-27-2018, 11:55 AM
Users browsing this thread: 13 Guest(s)
91H Code 126 Restore
There are currently 4048 online users. [Complete List]
» 1 Member(s) | 4047 Guest(s)
