Zenith R600 TO garbled reception
Is the 1L6 getting 1.5V to the heater? A bad selenium rectifier can cause this voltage to drop below 1.2V. Then to osc. will stop.
Zenith R600 TO garbled reception - by RodB - 01-30-2019, 10:02 PM
RE: Zenith R600 TO garbled reception - by OZ4 - 01-30-2019, 10:26 PM
RE: Zenith R600 TO garbled reception - by OZ4 - 01-30-2019, 11:15 PM
RE: Zenith R600 TO garbled reception - by David - 01-31-2019, 10:42 AM
RE: Zenith R600 TO garbled reception - by Phlogiston - 01-31-2019, 11:02 AM
RE: Zenith R600 TO garbled reception - by RodB - 04-12-2019, 02:02 PM
