Arran, Ok Thanks I will recap anyway.. Looks like some were not even close.. Probably only values they had at the time..
I think at lease one of the IF's was replaced as it matches the 2nd If used in a 36X or the 2nd production run of the 15X..
Has 6 leads instead of 4...
Skip
RCA 15X - by vecher - 01-31-2019, 10:43 PM
RE: RCA 15X - by Radioroslyn - 01-31-2019, 11:37 PM
RE: RCA 15X - by vecher - 02-01-2019, 12:21 AM
RE: RCA 15X - by Arran - 02-01-2019, 12:24 AM
RE: RCA 15X - by vecher - 02-01-2019, 12:38 AM
RE: RCA 15X - by vecher - 02-03-2019, 11:27 AM
RE: RCA 15X - by David - 02-03-2019, 10:00 PM
RE: RCA 15X - by vecher - 02-03-2019, 10:58 PM
RE: RCA 15X - by vecher - 02-04-2019, 09:32 PM
RE: RCA 15X - by Paul Philco322 - 02-04-2019, 09:49 PM
RE: RCA 15X - by vecher - 02-06-2019, 10:18 AM
RE: RCA 15X - by Ron Ramirez - 02-06-2019, 12:34 PM
RE: RCA 15X - by vecher - 02-06-2019, 04:54 PM
RE: RCA 15X - by Paul Philco322 - 02-06-2019, 08:38 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
There are currently 2561 online users. [Complete List]
» 4 Member(s) | 2557 Guest(s)
AvatarAvatarAvatarAvatar
