GE 200 Reception issue
Hi Paul,
Are all the 12 volt tubes, metal tubes? This might make a difference if some are Glass. Or maybe one you replaced is causing the issue. I’ve had this happen before. Also, poor ground connections to chassis could cause strange behavior. Just some of my random thoughts.
Tony
GE 200 Reception issue - by Paul Philco322 - 02-01-2019, 06:16 PM
RE: GE 200 Reception issue - by jcassity - 02-01-2019, 06:47 PM
RE: GE 200 Reception issue - by David - 02-01-2019, 06:55 PM
RE: GE 200 Reception issue - by tbone - 02-02-2019, 07:31 AM
RE: GE 200 Reception issue - by Arran - 02-02-2019, 05:59 PM
RE: GE 200 Reception issue - by Paul Philco322 - 02-02-2019, 08:28 PM
RE: GE 200 Reception issue - by Paul Philco322 - 02-04-2019, 10:33 PM
RE: GE 200 Reception issue - by Paul Philco322 - 02-11-2019, 08:56 PM
RE: GE 200 Reception issue - by David - 02-12-2019, 01:31 PM
RE: GE 200 Reception issue - by Eliot Ness - 02-12-2019, 05:07 PM
RE: GE 200 Reception issue - by David - 02-12-2019, 06:44 PM
RE: GE 200 Reception issue - by Paul Philco322 - 02-12-2019, 09:16 PM
With these values I think you are OK; the Cmax for this tube is 40uF. Your Vbb could rise a bit, but probably not too m...morzh — 04:53 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
There are currently 1945 online users. [Complete List]
» 3 Member(s) | 1942 Guest(s)
