Advice for removing finish on a 37-650
(01-21-2019, 09:59 AM)Ron Ramirez Wrote:  DO NOT USE DCL-PH7 or DCL-PH9. The fonts are these are grossly incorrect. Why they keep selling these, I do not know...
DCL-PH8 looks incorrect on their website but what you receive will be the correct 1932-1936 (and early 1937) font.
The medium size PHILCO decal in DCL-PH1 would be a good choice for later production 1937 and 1938 model Philcos.
wow..
see its the little things like these kinds of facts that qualify as a "right click, save as"
there is no way anyone would know this unless they ask the only person on the planet who does.... the level of knowledge and  detail here is impeccable.
RE: Advice for removing finish on a 37-650 - by jcassity - 02-04-2019, 12:47 PM
