Need a picture of a 37-640
Forgot to answer your speaker question.
Yes, it can be saved, and it will require reconing. That would be much better than converting it to use a PM speaker, which you want to avoid if at all possible.
I don't have the details on how to measure the depth of speaker cones. If I'm not mistaken, I believe it involves using a straightedge to measure the depth from the top of the cone to the inside.
Need a picture of a 37-640 - by Snowmann35 - 10-27-2010, 09:21 PM
Re: Need a picture of a 37-640 - by Snowmann35 - 10-27-2010, 09:22 PM
Re: Need a picture of a 37-640 - by Ron Ramirez - 10-27-2010, 09:30 PM
Re: Need a picture of a 37-640 - by Snowmann35 - 10-28-2010, 11:03 PM
Re: Need a picture of a 37-640 - by Snowmann35 - 10-28-2010, 11:04 PM
Re: Need a picture of a 37-640 - by Snowmann35 - 10-28-2010, 11:09 PM
Re: Need a picture of a 37-640 - by Snowmann35 - 10-28-2010, 11:17 PM
Re: Need a picture of a 37-640 - by Ron Ramirez - 10-29-2010, 09:02 AM
Re: Need a picture of a 37-640 - by Ron Ramirez - 10-29-2010, 09:07 AM
Re: Need a picture of a 37-640 - by Snowmann35 - 10-29-2010, 05:03 PM
Re: Need a picture of a 37-640 - by codefox1 - 10-30-2010, 11:24 AM
Re: Need a picture of a 37-640 - by Steve Davis - 10-30-2010, 06:31 PM
Re: Need a picture of a 37-640 - by 7estatdef - 10-30-2010, 06:39 PM
Re: Need a picture of a 37-640 - by Snowmann35 - 10-30-2010, 07:11 PM
Re: Need a picture of a 37-640 - by Snowmann35 - 10-30-2010, 07:12 PM
Re: Need a picture of a 37-640 - by Steve Davis - 10-30-2010, 11:07 PM
Re: Need a picture of a 37-640 - by 7estatdef - 10-31-2010, 06:18 PM
There are currently 10579 online users. [Complete List]
» 3 Member(s) | 10576 Guest(s)
