Threads: 46
City: Gap Mills Wv 24941
i ran across a post on some other thread where the person said they use single conductor copper wire as its easy to work with instead of the multi-conductor flex equal version.
i somewhat disagree and agree however...
you strip and twist the end and tin,, it becomes a solid end so its equal.
i always pre-tin the wires before i j hook and insert them into the radio connection. this reduces the time required on the part with heat.
i also use flux which a lot of people think the flux core in solder is good enough. using flux cuts your time on point with heat by more than 50%.
RE: 37-116 Restoration - by jcassity - 02-07-2019, 11:12 AM
Users browsing this thread: 15 Guest(s)
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
91H Code 126 Restore
Just to make it more confusing here is another model 91 schematic that doesn't show parts with dotted lines in that spot...Arran — 10:37 PM |
The wires were desoldered from the can, and the capacitors checked. All checked at 0.102 uF, which is correct.
So the c...morzh — 09:41 PM |
Yours probably then the H speaker, same as mine.morzh — 08:39 PM |
Mike;
I would like to have a look at the speaker in my model 96, but the set is packed into a corner in the basement. ...Arran — 08:04 PM |
Thanks Arran,
I'm convinced the power cord is good but have a nice repro plug for it. Would it be prudent to add a fus...RealRider — 07:28 PM |
As I was studying this schematic I was wondering what does this dotted line means? I haven't traced it out yet.
An o...RealRider — 07:22 PM |
