42-RP-2 weak
Hi Skip,
I would guess you would see around 150-220vdc at the cathode of the 84 tube. You could try a different audio source than the cartridge. You would use something that has a high impedance output. Say like a portable CD player.It has a low impedance output but you can raise the impedance by adding an output transformer or small filament transformer.. Use the headphone jack output into a tube type output transformer. Speaker side or 6.3v side to the phone jack/ Plate side or 120v side to the cartridge leads. I noticed that the output signal is fed back into the ac line cord. You may try flipping the plug over for best signal.
Good luck
42-RP-2 weak - by Skip - 10-27-2010, 11:20 PM
Re: 42-RP-2 weak - by Ron Ramirez - 10-28-2010, 11:01 AM
Re: 42-RP-2 weak - by Skip - 10-28-2010, 12:51 PM
Re: 42-RP-2 weak - by Ron Ramirez - 10-28-2010, 01:11 PM
Re: 42-RP-2 weak - by 7estatdef - 10-29-2010, 07:15 PM
Re: 42-RP-2 weak - by Skip - 10-30-2010, 12:07 AM
Re: 42-RP-2 weak - by 7estatdef - 10-30-2010, 06:22 AM
Philco 89 indicator light.
There are currently 4451 online users. [Complete List]
» 1 Member(s) | 4450 Guest(s)
