Precise 111 Restoration.
One other minor difference between the 111 and 111M, since the M tests tubes with more pins (12), there is 2 extra positions on the "Shorts" switch.
Tim
Precise 111 Restoration. - by Sampler1 - 01-03-2019, 11:24 PM
RE: Precise 111 Restoration. - by TV MAN - 01-04-2019, 12:37 AM
RE: Precise 111 Restoration. - by Sampler1 - 01-10-2019, 12:10 AM
RE: Precise 111 Restoration. - by Sampler1 - 01-14-2019, 02:44 AM
RE: Precise 111 Restoration. - by mikethedruid - 01-14-2019, 05:33 AM
RE: Precise 111 Restoration. - by Sampler1 - 01-14-2019, 01:55 PM
RE: Precise 111 Restoration. - by TV MAN - 01-24-2019, 10:43 PM
RE: Precise 111 Restoration. - by Sampler1 - 02-08-2019, 01:15 AM
RE: Precise 111 Restoration. - by TV MAN - 02-08-2019, 11:19 AM
RE: Precise 111 Restoration. - by TV MAN - 02-09-2019, 08:52 PM
RE: Precise 111 Restoration. - by Sampler1 - 02-10-2019, 07:47 PM
RE: Precise 111 Restoration. - by TV MAN - 02-11-2019, 03:47 PM
RE: Precise 111 Restoration. - by Sampler1 - 02-12-2019, 09:26 PM
