Need a picture of a 37-640
Hi Snowmann, if you want to recone the speaker your self, here are some cones I have used on Philco speakers.
http://www.electronix.com/speaker-replac...13892.html
Also, here is another place.
http://www.matelectronics.com/acatalog/M...s_208.html
I have not tried them though.
M R Radios   C M Tubes
Need a picture of a 37-640 - by Snowmann35 - 10-27-2010, 09:21 PM
Re: Need a picture of a 37-640 - by Snowmann35 - 10-27-2010, 09:22 PM
Re: Need a picture of a 37-640 - by Ron Ramirez - 10-27-2010, 09:30 PM
Re: Need a picture of a 37-640 - by Snowmann35 - 10-28-2010, 11:03 PM
Re: Need a picture of a 37-640 - by Snowmann35 - 10-28-2010, 11:04 PM
Re: Need a picture of a 37-640 - by Snowmann35 - 10-28-2010, 11:09 PM
Re: Need a picture of a 37-640 - by Snowmann35 - 10-28-2010, 11:17 PM
Re: Need a picture of a 37-640 - by Ron Ramirez - 10-29-2010, 09:02 AM
Re: Need a picture of a 37-640 - by Ron Ramirez - 10-29-2010, 09:07 AM
Re: Need a picture of a 37-640 - by Snowmann35 - 10-29-2010, 05:03 PM
Re: Need a picture of a 37-640 - by codefox1 - 10-30-2010, 11:24 AM
Re: Need a picture of a 37-640 - by Steve Davis - 10-30-2010, 06:31 PM
Re: Need a picture of a 37-640 - by 7estatdef - 10-30-2010, 06:39 PM
Re: Need a picture of a 37-640 - by Snowmann35 - 10-30-2010, 07:11 PM
Re: Need a picture of a 37-640 - by Snowmann35 - 10-30-2010, 07:12 PM
Re: Need a picture of a 37-640 - by Steve Davis - 10-30-2010, 11:07 PM
Re: Need a picture of a 37-640 - by 7estatdef - 10-31-2010, 06:18 PM
There are currently 10002 online users. [Complete List]
» 3 Member(s) | 9999 Guest(s)
