Need a picture of a 37-640
Snowmann and tery, this is how I do it. After cleaning the frame, cut some shims from some old film negatives. Make them about 3/16" wide and about 2" long. Place 3 or 4 shims in the voice coil slot, evenly spaced all the way around. Now slip the voice coil in the slot and install the screw in the spider. The shims will keep the coil centered in the slot. Test fit the cone. When satisfied with the fit, glue the cone to the frame. Use contact cement for this. Last glue the cone to the voice coil/spider. I use Elmers glue for this, but be careful and don't let any glue get in the voice coil slot. After the glue dries, remove the shims. Now push the cone in and out to make sure the voice coil does not rub. If it rubs slightly, You may be able to loosen the screw in the spider and shift the coil a little. One more thing. The foam surround on these cones, are a little thicker than the flange on the speaker frame, so when you mount the speaker, you will need to use a spacer on each mounting bolt so the foam dosen't touch the mounting board. If the foam touches the board, it will cause distortion. That's it! Good luck with your project!
M R Radios   C M Tubes
Need a picture of a 37-640 - by Snowmann35 - 10-27-2010, 09:21 PM
Re: Need a picture of a 37-640 - by Snowmann35 - 10-27-2010, 09:22 PM
Re: Need a picture of a 37-640 - by Ron Ramirez - 10-27-2010, 09:30 PM
Re: Need a picture of a 37-640 - by Snowmann35 - 10-28-2010, 11:03 PM
Re: Need a picture of a 37-640 - by Snowmann35 - 10-28-2010, 11:04 PM
Re: Need a picture of a 37-640 - by Snowmann35 - 10-28-2010, 11:09 PM
Re: Need a picture of a 37-640 - by Snowmann35 - 10-28-2010, 11:17 PM
Re: Need a picture of a 37-640 - by Ron Ramirez - 10-29-2010, 09:02 AM
Re: Need a picture of a 37-640 - by Ron Ramirez - 10-29-2010, 09:07 AM
Re: Need a picture of a 37-640 - by Snowmann35 - 10-29-2010, 05:03 PM
Re: Need a picture of a 37-640 - by codefox1 - 10-30-2010, 11:24 AM
Re: Need a picture of a 37-640 - by Steve Davis - 10-30-2010, 06:31 PM
Re: Need a picture of a 37-640 - by 7estatdef - 10-30-2010, 06:39 PM
Re: Need a picture of a 37-640 - by Snowmann35 - 10-30-2010, 07:11 PM
Re: Need a picture of a 37-640 - by Snowmann35 - 10-30-2010, 07:12 PM
Re: Need a picture of a 37-640 - by Steve Davis - 10-30-2010, 11:07 PM
Re: Need a picture of a 37-640 - by 7estatdef - 10-31-2010, 06:18 PM
Philco 91 Restore Code ??
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
