Threads: 49
City: Allendale, MI
It's really not that different from rewinding the osc coils on older Philcos, just a bit smaller with more taps on the primary. You have to rewind the entire coil as the primary wire also has the green corrosion. But it is still just a single layer on each of the windings. Very doable.
Russ, I would agree with you. There were a lot of spots where the corrosion was evident. As you said, if it's ok now, it won't be for long.
(This post was last modified: 02-12-2019, 01:57 PM by rfeenstra.)
RE: 37-116 Restoration - by rfeenstra - 02-12-2019, 01:55 PM
Users browsing this thread: 13 Guest(s)
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
91H Code 126 Restore
Just to make it more confusing here is another model 91 schematic that doesn't show parts with dotted lines in that spot...Arran — 10:37 PM |
The wires were desoldered from the can, and the capacitors checked. All checked at 0.102 uF, which is correct.
So the c...morzh — 09:41 PM |
Yours probably then the H speaker, same as mine.morzh — 08:39 PM |
Mike;
I would like to have a look at the speaker in my model 96, but the set is packed into a corner in the basement. ...Arran — 08:04 PM |
Thanks Arran,
I'm convinced the power cord is good but have a nice repro plug for it. Would it be prudent to add a fus...RealRider — 07:28 PM |
As I was studying this schematic I was wondering what does this dotted line means? I haven't traced it out yet.
An o...RealRider — 07:22 PM |
