Another Bing comes off the line
Thanks Jeff,
The video explains the cart.. I used a P51-3, It is a perfect and the sound is great.
Greg, I have perfected the art of not removing the chassis. I pull it out of the holes and turn it counter clockwise while flipping it. Then do the recap right in the cabinet.. Works every time but once I broke an antenna wire. I'm into lazy ways, Icon_lol
Icon_smile
Another Bing comes off the line - by OldRestorer - 02-12-2019, 03:13 PM
RE: Another Bing comes off the line - by OldRestorer - 02-13-2019, 12:14 PM
RE: Another Bing comes off the line - by Arran - 02-17-2019, 10:44 PM
There are currently 4423 online users. [Complete List]
» 1 Member(s) | 4422 Guest(s)
