GE g-97
I got the candohm problem sorted out, Speaker has a hum, But no response to dial or anything, I injected a signal on the blue wire (see diagram above) going to output transformer, and I can just make out the tone if I stick my ear into the speaker cone. If Im correct that is pointing towards a problem in my output transformer. which is strange since the resistance measurements where correct. Am I on the right track here?
GE g-97 - by rperry - 02-09-2019, 01:18 PM
RE: GE g-97 - by mark123 - 02-11-2019, 03:11 PM
RE: GE g-97 - by rperry - 02-11-2019, 09:15 PM
RE: GE g-97 - by jcassity - 02-12-2019, 09:58 AM
RE: GE g-97 - by 35Z5 - 02-12-2019, 10:40 AM
RE: GE g-97 - by rperry - 02-12-2019, 12:04 PM
RE: GE g-97 - by rperry - 02-13-2019, 06:21 PM
RE: GE g-97 - by 35Z5 - 02-13-2019, 09:22 PM
RE: GE g-97 - by rperry - 02-14-2019, 10:37 AM
RE: GE g-97 - by 35Z5 - 02-14-2019, 12:41 PM
RE: GE g-97 - by rperry - 02-14-2019, 07:16 PM
RE: GE g-97 - by 35Z5 - 02-14-2019, 08:57 PM
RE: GE g-97 - by rperry - 02-14-2019, 09:04 PM
RE: GE g-97 - by 35Z5 - 02-15-2019, 11:02 AM
RE: GE g-97 - by rperry - 02-15-2019, 06:35 PM
RE: GE g-97 - by jcassity - 02-15-2019, 07:59 PM
RE: GE g-97 - by 35Z5 - 02-15-2019, 08:09 PM
RE: GE g-97 - by jcassity - 02-16-2019, 11:51 AM
RE: GE g-97 - by David - 02-16-2019, 12:15 PM
RE: GE g-97 - by rperry - 02-17-2019, 08:41 PM
RE: GE g-97 - by rperry - 02-19-2019, 02:07 PM
RE: GE g-97 - by Kenneth F. Besso Jr. - 02-19-2019, 07:46 PM
RE: GE g-97 - by rperry - 02-19-2019, 10:18 PM
RE: GE g-97 - by 35Z5 - 02-20-2019, 03:07 PM
RE: GE g-97 - by morzh - 02-20-2019, 03:43 PM
RE: GE g-97 - by rperry - 03-06-2019, 01:54 PM
RE: GE g-97 - by rperry - 03-08-2019, 07:31 PM
RE: GE g-97 - by Radioroslyn - 03-08-2019, 08:21 PM
RE: GE g-97 - by rperry - 03-15-2019, 12:39 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
There are currently 2526 online users. [Complete List]
» 3 Member(s) | 2523 Guest(s)
