Threads: 49
City: Allendale, MI
Russ, you mentioned that you did/do not use the separator between the primary and secondary. Does that work in all cases or just when you use new wire for both primary and secondary? No doubt that the modern enamel insulation is much better than the old stuff. I used a separator cuz the original did. Off course the original caused the problems in the first place. You can see one of the green spots in this photo. I used tape as the separator hoping that the adhesive would not cause a problem down the line. To help against that and to hold the wires in place, bees wax was melted over the windings before the tape was applied. I'm also counting on today's insulation materials to be more immune from chemical attack.
RE: 37-116 Restoration - by rfeenstra - 02-15-2019, 11:46 AM
Users browsing this thread: 16 Guest(s)
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
91H Code 126 Restore
Just to make it more confusing here is another model 91 schematic that doesn't show parts with dotted lines in that spot...Arran — 10:37 PM |
The wires were desoldered from the can, and the capacitors checked. All checked at 0.102 uF, which is correct.
So the c...morzh — 09:41 PM |
Yours probably then the H speaker, same as mine.morzh — 08:39 PM |
Mike;
I would like to have a look at the speaker in my model 96, but the set is packed into a corner in the basement. ...Arran — 08:04 PM |
Thanks Arran,
I'm convinced the power cord is good but have a nice repro plug for it. Would it be prudent to add a fus...RealRider — 07:28 PM |
As I was studying this schematic I was wondering what does this dotted line means? I haven't traced it out yet.
An o...RealRider — 07:22 PM |
There are currently 4082 online users. [Complete List] » 1 Member(s) | 4081 Guest(s)
