GE g-97
    I started investigating the speaker and output transformer again and I made a few discoveries. On the connector where the "green" wire attaches the solder and wire are missing from the pin. (see Picture) also when I took my initial resistance readings I made an error. Where the schematic is showing 5 ohms across the speaker leads I have .9.. So it looks like I'm on the hunt for a new output transformer.
Ryan
GE g-97 - by rperry - 02-09-2019, 01:18 PM
RE: GE g-97 - by mark123 - 02-11-2019, 03:11 PM
RE: GE g-97 - by rperry - 02-11-2019, 09:15 PM
RE: GE g-97 - by jcassity - 02-12-2019, 09:58 AM
RE: GE g-97 - by 35Z5 - 02-12-2019, 10:40 AM
RE: GE g-97 - by rperry - 02-12-2019, 12:04 PM
RE: GE g-97 - by rperry - 02-13-2019, 06:21 PM
RE: GE g-97 - by 35Z5 - 02-13-2019, 09:22 PM
RE: GE g-97 - by rperry - 02-14-2019, 10:37 AM
RE: GE g-97 - by 35Z5 - 02-14-2019, 12:41 PM
RE: GE g-97 - by rperry - 02-14-2019, 07:16 PM
RE: GE g-97 - by 35Z5 - 02-14-2019, 08:57 PM
RE: GE g-97 - by rperry - 02-14-2019, 09:04 PM
RE: GE g-97 - by 35Z5 - 02-15-2019, 11:02 AM
RE: GE g-97 - by rperry - 02-15-2019, 06:35 PM
RE: GE g-97 - by jcassity - 02-15-2019, 07:59 PM
RE: GE g-97 - by 35Z5 - 02-15-2019, 08:09 PM
RE: GE g-97 - by jcassity - 02-16-2019, 11:51 AM
RE: GE g-97 - by David - 02-16-2019, 12:15 PM
RE: GE g-97 - by rperry - 02-17-2019, 08:41 PM
RE: GE g-97 - by rperry - 02-19-2019, 02:07 PM
RE: GE g-97 - by Kenneth F. Besso Jr. - 02-19-2019, 07:46 PM
RE: GE g-97 - by rperry - 02-19-2019, 10:18 PM
RE: GE g-97 - by 35Z5 - 02-20-2019, 03:07 PM
RE: GE g-97 - by morzh - 02-20-2019, 03:43 PM
RE: GE g-97 - by rperry - 03-06-2019, 01:54 PM
RE: GE g-97 - by rperry - 03-08-2019, 07:31 PM
RE: GE g-97 - by Radioroslyn - 03-08-2019, 08:21 PM
RE: GE g-97 - by rperry - 03-15-2019, 12:39 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
There are currently 2585 online users. [Complete List]
» 4 Member(s) | 2581 Guest(s)
AvatarAvatarAvatarAvatar
